Cement cleaner
Old Dec 13, 2001 | 10:34 PM
Ratsmoker's Avatar
Ratsmoker
Cement cleaner
Old Dec 17, 2001 | 08:28 PM
1ole4d's Avatar
1ole4d
Cement cleaner
Does anyone know of a good concrete cleaner to clean up a garage floor with? I want to try and clean mine up some. You know...get some of the oil spots and grime out. I know it'll never look new again but I'm tired of it looking like a grease pit.
Please don't pull out in front of me! I can't afford to play "What's this?" with you or your car.
Old Dec 17, 2001 | 08:39 PM
Greywolf's Avatar
Greywolf
Cement cleaner
2 Answers:
Use a mix of laundry detergent, and dishwashing soap (NOT automatic soap). Sprinkle it on, wet it, then go over it with a push broom.
If that don't do it, do this:
Rent a pressure washer
(a good pressure washer kin take the stink off a pole-cat! -If you can get it to hold still...)
Old Dec 17, 2001 | 08:50 PM
Mil1ion's Avatar
Mil1ion
Cement cleaner
A very GOOD inexpensive product called T.S.P. works wonders and is
water soluable ,so it won't hurt the environment.
If you are going to paint it after make sure you Etch the concrete with say 20% Muratic Acid.
Paint, Then Seal.
Dennis
It's Almost Time Everyone.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=314&.jpg
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Dec 18, 2001 | 08:29 AM
lanero's Avatar
lanero
Cement cleaner
My favorite is similar to Greywolf's. I use about a cup of Tide to a gallon of hot water. Scrub that into the floor, let sit for awhile. (long enough to consume one of your favorite beverages.) Then spray off. It even removed (most) of the 20 year old used gear lube I spilled.
Roger Lane
Old Dec 18, 2001 | 01:01 PM
cigarxtc's Avatar
cigarxtc
Cement cleaner
Castrol Degreaser(purple bottle) keeps my engine compartment, garage floor and driveway oil free and is biodegradable when following the directions on the bottle. It calls for adding water. It's similar to Simple Green, but less expensive and available most everywhere.
Old Dec 18, 2001 | 10:00 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Cement cleaner
Any of the detergents and water mentioned above, plus pour on some Clorox bleach. Scrub well with a broom with short stiff bristles. Let it sit, then hose off. Repeat as necessary.
Old Dec 19, 2001 | 10:11 AM
AZ4x4f150's Avatar
AZ4x4f150
Cement cleaner
[updated:LAST EDITED ON 19-Dec-01 AT 11:12 AM (EST)]well the way I clean mine isn't exactly politically correct but it works great is i use kerosene and a good stiff scrub brush then a biodegradable degreaser to emulsify the kerosene OH YA DON'T SMOKE WHILE DOING THIS it gets kinda exciting when you do that.
Or you can go out and get a couple cans of oven cleaner and let it sit alittle bit it works okay also
Old Dec 19, 2001 | 11:24 AM
cpnhgnjnky's Avatar
cpnhgnjnky
Cement cleaner
Castrol makes a product called Super Clean. I think someone mentioned it earlier but didn't put a name to it. The only thing is if you use it straight then avoid getting it on paint. If you use the hand held spray bottle its dilutted, in the gallon or bigger jugs its straight solvent. Get the floor wet, then spray it on let it soak for 10-15 minutes then if it needs it scrub. This stuff works great, I used to use it at my old shop to clean the floor.
CJ
Old Dec 19, 2001 | 11:57 AM
truckfreak69's Avatar
truckfreak69
Cement cleaner
My shop teacher always used comet and water and swooshed it around with a big shop broom, worked pretty well.
Old Dec 19, 2001 | 12:39 PM
deere81's Avatar
deere81
Cement cleaner
You might try some muriatic acid. I think it is used for cleaning. Its some powerful stuff.
Rusty_S
Jul 30, 2010 11:56 AM
LaredoF350
Aug 18, 2009 11:43 AM
kpwall
Dec 14, 2006 04:52 PM
Greywolf
26
Jul 15, 2005 12:46 AM
FTE Ken
Jan 2, 2002 04:16 PM
