identification/help
Old Feb 15, 2005 | 08:42 PM
keeper's Avatar
keeper
identification/help
This is from a '78 F150 supercab, 4X4. Front differential.I don,t know where else to look. 3 50 D8TA AAE 610048-1.
Old Feb 15, 2005 | 09:34 PM
78fordman's Avatar
78fordman
Dana 44F most likely. 44 will be stamped into the housing, lower right if i remember right.
Old Feb 15, 2005 | 10:07 PM
keeper's Avatar
keeper
thanx.I should hav added this front diff is leaf spring mount
Old Feb 16, 2005 | 11:15 AM
keeper's Avatar
keeper
Ifound some more numbers on left side of the diff tube;7 20 8 C5 610048 1.maybe this will help.
Old Feb 16, 2005 | 08:38 PM
SoCalDesertRider's Avatar
SoCalDesertRider
The axle has a 3.50 ratio with an open differential. '78 F150's came with Dana 44 high-pinion front axles (reverse-cut gears) with disc brakes, open knuckles and ball joints. You can look up the 610048-1 Bill of Materials number on the Dana website: www2.dana.com/expert, in the light axle section. You need to download the .pdf file for '79-down trucks axle applications and you can find out where that axle came from if it is not the original one.
The rear should be a Ford 9".
Old Feb 16, 2005 | 08:58 PM
keeper's Avatar
keeper
thanx,this is a big help.
Old Feb 16, 2005 | 09:18 PM
keeper's Avatar
keeper
I can't get anything on that web link.Just says page not found.
Old Feb 17, 2005 | 12:04 AM
SoCalDesertRider
http://www2.dana.com/expert/wc.dll?cvsp~Depdf~5~AXL~
There is the link pasted from my browser url window. Go to section X510-8 'axle applications- model years 1967-78. The .pdf file will download if you have the Acrobat reader. Then choose the Ford front axle section.
