302 stumble
Old Feb 15, 2005 | 06:36 PM
guinness2199's Avatar
guinness2199
302 stumble
86 f150 stumbles
2around 4800 rpm. any ideas?
Old Feb 15, 2005 | 07:11 PM
mdstud's Avatar
mdstud
You try pulling the error codes to see if maybe theres a failing sensor.
Old Mar 7, 2005 | 06:48 PM
guinness2199
no codes, new cap rotor wires plugs,ff,.anyone exp. bad injectors? real hard to find out wich cyl is missing @4400-4800 under load. have lost 3 runs from this.$nothing outlandish has been done to my truck, fresh fomoco block,cleaned up heads w/ new fact valves,no cracked seats everything is straight. just short of putting it on the emmisions dyno@work(will probably break it)im lost.
Old Mar 7, 2005 | 07:04 PM
frty7ford's Avatar
frty7ford
either fuel dilivery or spark
Old Mar 7, 2005 | 07:14 PM
guinness2199
did swap coil w known good one.almost every ign mod ive seen go bad just wont run.di replace 2 inj for severe miss about 6 mos ago. has dual tanks and acts the same on both. do occasionally notice a fuel smell when on lift @ underneath. i have 2 ase L1 cert guys in my shop, and both are clueless w/ me.
Old Mar 8, 2005 | 12:24 AM
mstarr's Avatar
mstarr
If your racing, I would guess that the factory pump can't keep up. Replace the high pressure pump with a high flow unit.
Only way to tell FOR SURE is to run with a fuel pressure guage installed. Only problem is you can't see it at 70mph! So you have to take the hood off and secure to gauge where you can see it. Or just change it and see if it fixes it!
Old Mar 9, 2005 | 07:16 PM
guinness2199
thats about at the end of my list. know of any dependable aftmkt pumps?
