Sponsored by: Real Truck
Iac
Old Feb 15, 2005 | 06:03 PM
townhill4's Avatar
townhill4
Iac
What does IAC stand for and where is it on my 2000 5.4 SD?
Old Feb 15, 2005 | 06:10 PM
2000silverbullet's Avatar
2000silverbullet
It's the idle air controller. I'm tryin' to find out where it is on a 5.4 on the web. Someone might beat me to it though.
EDIT: I got nothin' for ya man, sorry. I'm sure others will chime in shortly.
Old Feb 15, 2005 | 06:22 PM
townhill4's Avatar
townhill4
Thanx silver. I was told to replace the IAC due to cold weather idle problems.Hopefully I can do it myself,and not pay $60 an hr.
Old Feb 15, 2005 | 06:26 PM
2000silverbullet
I know this is kind of a generic response, but a manual (chilton's/haynes) is well worth the money. I've managed to save myself alot of time and money using mine.
Good luck!
Old Feb 15, 2005 | 08:25 PM
high ho silver's Avatar
high ho silver
It is bolted to the back side of the throttle body with two small bolts. It is silver in color and has a wire plugged into it with a small rubber hose coming out the back.
Old Feb 15, 2005 | 08:55 PM
townhill4's Avatar
townhill4
Thanx silver. I found a picture of it after looking for a while in the forum.I'm goin to take it off tomorrow and clean it, I hope it solves the problem.
Old Feb 24, 2005 | 11:23 AM
DadX4's Avatar
DadX4
I removed mine ('00 ltd) last Sept. and cleaned it with gumout and an air hose.....took a total of less than 1 hour. Not a single startup or idle problem since. Clean it before you replace.
