Sponsored by: Auxito
Brake lights staying on
Old Feb 14, 2005 | 04:49 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Exclamation Brake lights staying on
I think I might need a new BOO (brake on/off) switch.My brake lights stay on after I shut off my truck.I can pull up on the pedal and they go out. November 2004 I replaced the switch when I could not get my shifter out of park.It was actually a broke wire at the switch.I kept the new switch in place but now i'm thinking its gone bad. Any ideas?
Old Feb 14, 2005 | 05:22 PM
projectSHO89's Avatar
projectSHO89
It might be the brake pedal return spring in the master cylinder. When it gets weak, it no longer pushes the pedal far enough to disengage the BOO.
The easiest fix is to add a spring under the dash to help pull the pedal back.
Steve
