water pump pulley?
Old Feb 14, 2005 | 12:09 PM
killswitch's Avatar
killswitch
Arrow water pump pulley?
I have a terrible scrapping/rattling noise in my 400 when the engine revs at low RPMs. I'm almost positve it is the water pump pulley. I'm just begining to learn about engines and I was wondering if this is a common problem. The performance of the engine seems the same, its just extremely bothersome to drive around with the noise. Is there anything else I should be on the lookout for. Any help or any information at all would be great. This is by far the best and most informative forum on the internet
Old Feb 14, 2005 | 01:16 PM
TxBrokenarrow's Avatar
TxBrokenarrow
do you have a fan clutch???something is not right..what year and model is it in??scrapping/rattling noise is never a good thing
Old Feb 14, 2005 | 01:32 PM
TxBrokenarrow
read on another post you had a 78.you shouldnt have a fan clutch...check to see that your fan blades arent in contact with your radiator shroud...a lose fan belt will also make a noise that might sound like rattling but not a scrape...could be water pump going out...keep a close eye on the water temp untill you find out what the problem is..good luck..let us know what you found out
Old Feb 14, 2005 | 03:07 PM
killswitch's Avatar
killswitch
I've been told it could be a bearing?? in the water pump pulley. Could something like this be the case? The temperature has remained normal.
Old Feb 14, 2005 | 03:12 PM
TxBrokenarrow
no bearing on the pulley but the water pump has a bearing.
Old Feb 14, 2005 | 03:16 PM
TxBrokenarrow
water pump pulley
as you can see there is no bearing...it just bolt's up to the water pump..
Old Feb 14, 2005 | 03:26 PM
TxBrokenarrow
you can try this but be very carefull you don't get your head caught in the fan...use a long screw driver and put the metal end on the water pump and the handle end up to your ear (like a doctor listening to your heart "stethascope") maybe even a broom handle and you should be able to hear if it's the water pump...but BE CAREFULL
Old Feb 14, 2005 | 03:57 PM
TxBrokenarrow
if you decide to replace the water pump...dig a little deeper and have a look at the timing chain and gears to see if they are worn...i read you may have had some timing issues...a good manual and a few tools can save you a bunch of $$$ unless you don't have the time..
Old Feb 14, 2005 | 04:25 PM
killswitch's Avatar
killswitch
I appreciate all the help, I plan on tackling this on the weekend with a few friends. I'll let you know what we find.
Old Feb 15, 2005 | 09:34 PM
kc5hwb's Avatar
kc5hwb
I have a 78 F150 and it DOES have a fan clutch.
I once had a noise like this and it turned out to be my alternator. Do what BrokenArrow said and put a screwdriver to the unit while it is running to hear it. But do be careful.
Old Feb 16, 2005 | 04:20 PM
killswitch's Avatar
killswitch
I have a brand new alternator however, but I will check with the method you said earlier. None of my guages are acting up though.
Old Feb 16, 2005 | 06:14 PM
hdgapeach's Avatar
hdgapeach
Heck, if you have a new alternator it probably ain't the cause. Take the v-belt off so the water pump pulley doesn't turn. Start the engine. If the noise is gone (since the pulley isn't turning) you've pretty much found the source.
Old Feb 16, 2005 | 09:14 PM
danlee's Avatar
danlee
Do you have an idler pulley? I have seen bearings go bad in idler pulleys. I pressed it out and went to a bearing supply house and match it up. Then I pressed it in and fixed the problem for a couple of bucks.
Old Feb 19, 2005 | 03:16 PM
killswitch's Avatar
killswitch
there was two different noises and we found both the water pump and the NEW alternator are trashed, is this just a coincidence or to I have a larger problem on my hands?
Old Feb 20, 2005 | 07:15 AM
danlee's Avatar
danlee
An over-tightened belt can cause excessive wear on the bearings.
