4 by 4 question
Old Feb 14, 2005 | 08:02 AM
badass_f-150's Avatar
badass_f-150
4 by 4 question
Hey I know this is kinda dumb but what would I have to buy to turn my 95 f-150 from a 2 wheel drive to 4 wheel drive. The engine is a straight 6.
Thanks
Old Feb 14, 2005 | 08:26 AM
Loganwildman's Avatar
Loganwildman
It would be much easier to just buy a 4x4. Otherwise, you would need to get a complete front end, springs and spring hangers then measure and drill all the mounting holes etc.
Old Feb 14, 2005 | 09:11 AM
MustangGT221's Avatar
MustangGT221
Nope...
The 4wd suspension will swap right inplace of the 2wd's...just as easily as removing the 2wd and putting the 2wd back. There is a tech article in that section (link on the right) that gives the basics....it's a topic that has definitely been talked about before, so please try our search.
Old Feb 14, 2005 | 06:40 PM
RLKBOB's Avatar
RLKBOB
front end, transfer case, drive shafts(front and rear because the rear will be shorter now), 4wd transmission or output shaft from a 4wd trans to swap onto your trans. TC skid plate. There might be a few more things.
