Sponsored by: Real Truck
Headlight Reversing Relay
Old Feb 14, 2005 | 07:19 AM
ccolburn's Avatar
ccolburn
All,
I need a little guidance here. A friend of mine told me he read a post about a relay that can be installed which reverses the behavior of the highbeam lever. This relay allows the forward position on the turn signal indicator to function as it does when pulled back upon for the "flash high beams" function. I am really interested in finding out where I can get one of these relays, because let's face it, the highbeams alone are just not bright enough for driving on remote dark roads.
Thanks,
cc
Old Feb 14, 2005 | 10:08 AM
Crash687's Avatar
Crash687
Running both filiaments in a bulb could cause overheating shortning bulb life, melting housings and wiring.
Try a set of Sylvania SilverStar bulbs, they make a huge differance.
http://www.sylvania.com/ConsumerProd...ce/Silverstar/
Old Feb 14, 2005 | 08:11 PM
Deaver's Avatar
Deaver
Maybe this is the item
I tried to link for you but follow as below
Click on the "PARTS SHOP" tab on the upper right of this page
Click on the Miscellaneous Items tab on the left side of the page that opens
Click on the "Brite Box Headlight Illumination" tab
