Sponsored by: Real Truck
Chasis Lube Question
Old Feb 13, 2005 | 11:16 PM
OfficerLow's Avatar
OfficerLow
As far as I know there are 4 points to lube under the chasis on a Super Duty. Is it possible to overlube? I noticed that when I add grease, the grease starts oozing out from the round rubber circles (it looks like they are rubber). It looks like the rubber circle expands for a second until I let off the grease gun. Is this normal?
Thanks
Old Feb 13, 2005 | 11:21 PM
Rawhide's Avatar
Rawhide
Yes This Is Normal
Old Feb 13, 2005 | 11:53 PM
n578md's Avatar
n578md
Not only is it normal but it's also useful. I pump new grease in until I see the run-off change color. Old grease is black and the stuff I put in (Mobil 1 Syn grease) is red. So when I see red stuff come out, I know I have displaced most of the old stuff and the boot is full of fresh grease.
Old Feb 13, 2005 | 11:59 PM
OfficerLow's Avatar
OfficerLow
Originally Posted by n578md
Not only is it normal but it's also usefull. I pump new grease in until I see the run-off change color. Old grease is black and the stuff I put in (Mobil 1 Syn grease) is red. So when I see red stuff come out, I know I have displaced most of the old stuff and the boot is full of fresh grease.
That's what I always thought, too. Pump in the new grease and push out the old dirty grease. But last time, a friend was watching and mentioned what I asked.
Thanks
Old Feb 14, 2005 | 12:03 AM
n578md's Avatar
n578md
I guess the bleed hole in the grease boots have two purposes; 1 so that the boots don't pop off or burst when you fill them and 2 so you can see when you've changed out the old grease.
