Hey guys, I'm looking at this battery tray (item 7953412716 on ebay) as a replacement but can't get the seller to reply with a Ford part #. Can anyone verify that this looks correct for my 85 F150, as I don't have access to my truck at the moment?
I'm now thinking its not correct. Looking at pics on the Bronco Graveyard site, this would be an '87 - '96 tray. Might work, but might not without fabrication.
I bought one at the dealer about 4 years ago. It cost $35. It was for my '84. I installed it yesterday on my '83. Glad I checked it out. The old box on the '83 was rotton, and about to let go.
I let the one on ebay go. It went for $44 without shipping. I figure I can get one from a junkyard that will work. It doesn't have to be pretty. LMC has them, but they want $74 if I recall correctly.
7283-F250, if you had to cut a hole in your fender, how is that fitting fine? Or was it just a bolt hole or something?
If I were you I would just go to Ford and buy it they go for around $40. not worth wasting your time on e-bay just to get a used one that might not fit
once the battery sits there for a while, nobody will notice anyway.
>If I were you I would just go to Ford and buy it they go for around $40. not >worth wasting your time on e-bay just to get a used one that might not fit
That was my original plan. My dealer said he couldn't get that part anymore.
Pretty common in the junkyards-up to 1996 models. Happily the later models are made of much heavier metal. It's a LOT easier to find a later one in good condition. I put one on my 82, much more robust than than the original ever was. And yes, I needed to drill one small bolt hole for a brace. No big deal though.
I am also looking for a battery tray. What year Ford tray worked for you?
