2002 ford ranger 4x4/starting problems
Old Feb 13, 2005 | 04:28 PM
beagler86's Avatar
beagler86
have a 02 ranger sohc 4.0 the problem is went out 2 start one day,would not start. the only way i could get it 2 start was 2 push on the gas then the truck would start,but would die if i let off the gas.had same problem about a year ago took 2 dealer 2 get fixed been fine till now. i have the same problem again the truck only has 27,000 on it. please help and where is part located
Old Feb 13, 2005 | 04:37 PM
Mil1ion's Avatar
Mil1ion
Welcome to FTE!
Please read this:
https://www.ford-trucks.com/forums/s...d.php?t=300691
Old Feb 13, 2005 | 07:13 PM
87 XLT's Avatar
87 XLT
Sounds like a bad IAC valve. Check out the XLNT thread on this from Wolfmeister. "IAC repair help" at the top of the Explorer forum
Old Jul 12, 2005 | 09:16 PM
beagler86's Avatar
beagler86
99 ford taurus alternator change
where can i find a web site on how 2 change alternator on my 99 ford taurs. ii had a altenator go bad about a year ago in same taurus,now it is bad again any reason why they may be going out. got alternator from napa it is a lifetime alternator but changing it and reason why they r going out hope someone can help thank you
Old Jul 13, 2005 | 07:49 PM
Ken00's Avatar
Ken00
It should be easy to change the alternator, remove the belt, remove the electrical connections, remove the bolts, install in the reverse order.
Rangerxltoffroad
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 26, 2015 09:05 PM
SmashingAces
May 19, 2014 02:30 PM
DavidMc70
Aug 11, 2013 11:32 PM
Vyndrah
Oct 28, 2012 01:34 PM
Beast12
Aug 26, 2003 05:36 AM
