351w motor mounts
Old Feb 13, 2005 | 02:59 PM
Fuzzy's Avatar
Fuzzy
351w motor mounts
351w was put in my 58.They cut on the crossmember and mounted the engine with homemade mounts.If I remove the crossmember and replace it with one of the tube type crossmembers I see is it going to weaken my front end ? Open for suggestions.
Old Feb 13, 2005 | 06:16 PM
fatfenders's Avatar
fatfenders
Fuzzy
You can add another crossmember near the transmission. Or you can box the frame. And many before you have done none of the above and report no big problems.
mikepedersen17
Jul 27, 2011 09:42 PM
Jim Anderson
New Member Introductions
Oct 10, 2007 08:28 PM
john061543
Jul 9, 2005 07:53 PM
six7seta
Mar 2, 2005 12:09 AM
77sc
May 14, 2002 06:08 PM
