Engine wont come out
Old Feb 16, 2005 | 05:18 PM
RawPower's Avatar
RawPower
Ill check, but I cant take out the engine today...my dad is using the tractor after work to shred our field (right now). Do 460's swap straight in?
Old Feb 16, 2005 | 06:48 PM
nogo73's Avatar
nogo73
no diesel to gas is a pain in the a
Old Feb 16, 2005 | 08:10 PM
RawPower's Avatar
RawPower
OK, just curious. But if I ever come across a 513ci, Im sure as hell gonna consider it...
Old Feb 17, 2005 | 08:24 AM
460429_freak's Avatar
460429_freak
no you cn't use the diesel tranny(auto) soemthing about the gearing and vacum? the 460 is lighter than the 6.9 also wiring a 460 is a sinch if you using the old dura spark system...
Old Feb 17, 2005 | 04:18 PM
RawPower's Avatar
RawPower
I have manual, but will not be swapping...
Old Feb 17, 2005 | 06:07 PM
82F100SWB's Avatar
82F100SWB
Is your flywheel shield unbolted?
Old Feb 17, 2005 | 07:49 PM
RawPower's Avatar
RawPower
I unbolted it, and yes it was holding it on (or at least one of the things). Then it was just binding. But it finally came out. Now I am trying to remove the flywheel. I removed all of the bolts underneath the clutch pad, but the clutch plate (I think) wont come off now. I need it off to bolt it to the engine mount.
jeff gammon
2004 - 2008 F150
Feb 6, 2015 07:43 PM
f1barry
26
Dec 18, 2010 02:53 PM
79 f-150 guy
General Automotive Discussion
Sep 26, 2009 02:44 PM
elemint
Aug 17, 2005 11:25 PM
