Transmission fluid leak INSIDE truck
Old Feb 13, 2002 | 12:42 PM
fordson's Avatar
fordson
OK, I know I'm not seeing things but it looks like red transmission fluid is dripping out from behind my dash. There will be a puddle on the floorboard to the left of the brake pedal. Where is it coming from? Speedometer cable? How do I fix it? It's an 85 F1504X4 with an aod.
Thanks,
Gary
Old Feb 13, 2002 | 01:50 PM
Mil1ion's Avatar
Mil1ion
This is odd & a first for me.
I can't quite see where it's coming from ,
from where I'm sitting.
Why not pull the instrument cluster and check the back of the speedo.
Also,check the trans end attachment to see if any runs Out of the cable when it is removed.
Dennis
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Feb 13, 2002 | 03:09 PM
slikness's Avatar
slikness
Pull the vacuum hose off the modulator valve on the tranny...if it has fluid in the line, replace the valve (you'll lose a lot of tranny fluid while you change the valve)...you might be getting some fluid in your vacuum lines and seeping in through your brake booster...
Good luck,
Old Feb 13, 2002 | 07:05 PM
onestep's Avatar
onestep
It is travling through your speedo cable. My speedo cable is squeeking right now and I have to lube it. Check the seals.
Old Feb 13, 2002 | 07:16 PM
destiny88's Avatar
destiny88
I would try the speedo cable. My body had a Monte Carlo that did the same thing and it was the seals were the cable scews on to the transmission.
Old Feb 15, 2002 | 01:38 PM
fordson's Avatar
fordson
Well when I went looking around yesterday, I found a fitting right above where the speedo cable hooks up to the the tranny. It had about a 1/3 inch piece of hose on it so I figured it must be a vent. Sure enough when I screwed it off air blew out. Blasted dirt daubers had stopped up the vent. So far I haven't had any more leaks.If this isn't a vent I hope someone lets me know. I checked the rear axle vent and it was plugged up too.
Gary
Old Feb 15, 2002 | 10:37 PM
rocky's Avatar
rocky
That's one of the wierdest problem I've heard. That's why I like this site, I learn something new all the time.
Old Feb 16, 2002 | 08:13 AM
MDR's Avatar
MDR
Gary F-250
Jun 3, 2011 11:35 AM
gcreed
Aerostar
Mar 8, 2005 09:14 PM
Gary42141
Dec 18, 2004 05:12 PM
46ford
1947 and Older Ford Trucks
Oct 25, 2002 07:17 PM
avcgroup
Apr 4, 2001 12:57 PM
