start up
Old Feb 13, 2005 | 07:09 AM
slicks94's Avatar
slicks94
start up
Hi i'm new to the forum,been reading all morning some great stuff in here.i have a 94 ranger with a 4.0 and a five speed 95 thousand mile on her.in the last year or so the truck does not start when left out in the rain,so i pull it in the garage and 20 minutes later she fire right up.the truck cranks over ok but just will not start.i have used dielectric grease on plugs and coil,and it does not help.does anyone have any ideas.
Old Feb 13, 2005 | 07:18 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Old Feb 13, 2005 | 10:24 AM
cobra351's Avatar
cobra351
something is shorting out when humidity gets up there around 100%. I would check everything assoc. with the ignition and start changing things out. One thing you could try is when it does that and if it's dark out open the hood and have someone crank the engine you might just see where the short is happening, if you are lucky. I'm not sure but if that year still has a distributor the cap and wires are a good place to start then the coil then the EEC module if it's distibutorless then it will be a little tougher to figure out without spending some bucks...good luck,,,Neil
Old Feb 13, 2005 | 02:09 PM
00BlueOvalRanger's Avatar
00BlueOvalRanger
What a pain this can be.
A few things to check:
As cobra351 said, I am not sure if the '94 had a distributor or some other ignition. With that in mind, IF it has a distributor, you should look for -
1. Hairline fractures on the distributor cap. (Have someone crank the engine over [at night/total darkness] and observe the cap. IF there are hairline fractures, you will see the current 'dancing' all around the cap, from tower to tower, maybe even down the sides to ground.)
Remedy: Replace distributor cap.
2. Bad or cracked ignition (spark plug) wires. Same test as #1, above.
Remedy: Replace spark plug wires.
3. Cracked coil. Same test as #1, above.
Remedy: Replace coil.
The above listed possiblilites are just the tip of the iceberg. The humidity problem is what is the 'kicker'. An old trick was to spray the components with hair spray. This will 'kinda waterproof' the components. (This doesn't last long.)
If you have already ruled out these possibilities, kindly disregard the post.
Old Feb 13, 2005 | 04:29 PM
slicks94's Avatar
slicks94
thanks a lot for your input,the truck does have a coil so maybe there is a crack in it.next time she does it i'll check it at night
Old Feb 13, 2005 | 05:03 PM
el conquistador's Avatar
el conquistador
next time it does it pull the codes. is it DIS or does it have a distributor
66 bronco roadster
Aug 9, 2012 08:29 AM
fordinmudd
Jul 11, 2010 02:13 AM
94F250_weekender
Oct 28, 2008 11:20 PM
lisagreer
Feb 20, 2008 01:15 PM
