metric od trany
Old Feb 12, 2005 | 09:54 PM
motordaddy's Avatar
motordaddy
metric od trany
well i hope i haven't complety destroyed my trany..on the way to work the neopreem holder for my tv cable broke i did not realize it untill i got to work about 40 miles...now after reinstallinn all the parts i only have 1st and 2nd...pls help
Old Feb 13, 2005 | 05:45 AM
theonlybull's Avatar
theonlybull
try adjusting the tv cable, it sounds like you have it too tight, and the tranny thinks your running at wot....
Old Feb 15, 2005 | 06:14 PM
Casey's Avatar
Casey
Did you see the reply between your two messages? That's what I would have suggested, but theonlybull beat me to it.
If you answer that question we can go from there.
Old Feb 16, 2005 | 05:09 AM
theonlybull
the only thing i changed was the neopreem holder on the throtle lever
did you get it in the exact same place it was i before? could it have moved before you changed it?
what you discribe, is what these tranny's will do when the cable's ay out of adjustment
Old Feb 16, 2005 | 06:35 PM
motordaddy's Avatar
motordaddy
thanks to all ill try it pls no offence ment im just very frustrated..my only transportation..thanks
