E Load Rated Tires
Old Feb 12, 2005 | 05:19 PM
robbieie's Avatar
robbieie
Wink E Load Rated Tires
Does Anyone Know If You Can Get A Higher Load Rated Tire For A 2001 Superduty. My Oem Tires Are Lt235-85r16 Load Range E. Do They Make A Load Range F That Will Fit My 16" Rim. Thanks For Any Info. I Have Tried Searching For This Info With No Luck
Old Feb 12, 2005 | 05:30 PM
barebackjake's Avatar
barebackjake
i havent seen any, well you can only put so much wieght on the truck legally and with E load range your well within the wieght limits. think you need a 19.5" wheel to go to higher wieght range.
Old Feb 12, 2005 | 05:54 PM
CAT_man_963's Avatar
CAT_man_963
Yea - if you're hauling that much weight - you better get a bigger TRUCK to go with the higher load range tires you want!! Seriously - load range E is more than enough for anything that you can load, stack, or drag with your Superduty
Old Feb 13, 2005 | 12:45 AM
semperfipsd's Avatar
semperfipsd
interco tire company has tires made for heavy hauling. They don't give the load range instead they give the lbs per tire. Pretty high rating, higher the BFG load range E I believe. I have been really interested in buying the interco trxus tires for my SD. However, I can't get anyone to give me real life experiences so I will probably go with the trusted BFG's! I still like the idea of converting to the 19.5 or 22 in alcoa rims but can't seem to come up with all the $ for that conversion. We did have a good thread on the 8 to 10 lug conversion a month or so ago. Do a search for my post or for 8 to 10 lug conversion. Those rims and tires would diffently handle all the wieght that you could/or shouldn't put on your SD.
