Lockers
Old Feb 12, 2005 | 03:32 PM
Rx7toys's Avatar
Rx7toys
Lockers
I have a 1995 Bronco , 8.8 rear and the dana 44 front. My axles are not LSD's . and I would like t throw a set of Lockers in it. I Do not have the cash to go with air or electric lockers, I just want the basic lockers. Anyone know which ones I need?
Thanks!
Old Feb 12, 2005 | 11:53 PM
SoCalDesertRider's Avatar
SoCalDesertRider
If you're sure you want actual locking diffs and not limited slips, you can put in Powertrax Lock Rights, about $300 each and they go in the stock open carriers. Check out www.powertrax.com. I have one in the rear axle of my F350 and like it alot. A buddy of mine has them in both axles of his Jeep CJ and they work good. Trac Tech also makes the Detroit Locker and EZ Locker too. Check them out at www.tractech.com. The Detroits are full-case and more expensive than the Lock Right. EZ Locker goes in the stock case and is priced close to the Lock Right.
Old Feb 13, 2005 | 12:59 AM
Rx7toys's Avatar
Rx7toys
Thanks!
Thanks very much!
