oil drain problem
Old Feb 11, 2005 | 05:44 PM
ray_bone40's Avatar
ray_bone40
oil drain problem
any one have the same problem that i have? i have a 65 ford f250 with a 352 and when i have to drain the oil it has the oil drain by a fuel line so that i can drain it but i want to relocate it so i can just open it and drain it so i dont have to wait there is a crossmember in the way to drain my oil
Old Feb 11, 2005 | 05:56 PM
Putt's Avatar
Putt
ray - run a search on oil drain and you will see that it is a common problem. Some use a Fram or Fumoto drain valve that lets you hook up a hose to it. Others have gone simple and fashioned a funnel of sorts to drain the oil into their drain pan.
I built my own custom pan and put the drain where I wanted it, along with considerable extra capacity!!
Old Feb 12, 2005 | 06:11 AM
jowilker's Avatar
jowilker
Ray, Welcome to the club of 65-76 year model trucks with FEs in them. We all feel yo pain.
Your fuel line should go around the side of the oil pan, so I don't understand your comment about it.
John
Old Feb 12, 2005 | 09:47 AM
Putt's Avatar
Putt
He might be thinking of the brake line clipped to the crossmember.
Old Feb 13, 2005 | 03:54 AM
ray_bone40's Avatar
ray_bone40
ok like is there another way to get a oil pan that would fit my 352 and have the drain else where
Old Feb 13, 2005 | 01:42 PM
Putt's Avatar
Putt
You could check out other year, model Trucks and cars to see if any have different drain locations. I haven't seen a more acceptable drain at my local wrecking yard yet.
Old Feb 13, 2005 | 09:25 PM
FordBoypete's Avatar
FordBoypete
Ray,
I have to concur with my friend Putt, the way around the problem is install another drain plug where you need it like Putt says. That's what I do. This is always a problem when a passenger car engine is installed in a F Series chassis. I have same deal with 460s out of a P-Car.
The only problem is pan has to come off to really do it right, but IMHO it's worth it.
FBp
Old Feb 14, 2005 | 10:33 AM
Mike G's Avatar
Mike G
The FE powered 4x4 truck came with a rear sump oil pan. If you are fortunate enough to find one, you will also want to grab the pick up tube to go with it. Check with your favorite machine shop or speed shop, they can also wrangle up a pan for you. Of course those will be the aftermarket pretty and $$ ones.
--Mike
Old Feb 14, 2005 | 12:16 PM
jav409's Avatar
jav409
Or you could go to a marine dealer and get a oil pump that has a small tube that runs down the dipstick into the bottom fo the oil pan and sucks all the oil out.not only does it work but you dont end up with oil all over the place.I also punch a hole in the oil filter suck the oil out with the same pump then put a peice of ducttape over the hole and spin the filter off, can do it without ever going under the truck.
Old Feb 14, 2005 | 01:27 PM
matt1morton's Avatar
matt1morton
does that fram drain valve work? does it leak? and does it look stupid?
