Windshield wiper switch knob removal
Herdsman
Good luck
Raul
Wait,wait. I wouldn't just pry it off, you'll brake the the part that holds it on. Here's how I do it, suggest you make up your own procedure to duplicate my results:
Use a very small nail (I use small paneling nail because they are hard and I know where they are) Put a 90 degree bend in the tip (last 1/16 - 1/8),(more acute than 90 is helpful, so you actually have the tip coming slightly back)). Clip the nail head in a set of needle nose vice grips (tight, 'cause it'll want to move).
Place bent tip into the **** slot (twist **** left or right for work comfort) and pull on the vice grips/nail, not on the ****. When you pull the **** the holding mechanism gets tighter on the shaft, when you pull on the nail, it releases the grip.
Suggest you don't just pull on the ****.
Raul
w/ 81 F-100, I6, SROD, Carter 1V non-feedback carb, no A/C, no PS, no PB, but it gets me where I need to go
1986 F-150 4x4 300 I6 NP435
Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint
There is a small piece of spring steel friction fitting the wiper switch shaft.
Look underneath on the bottom of the **** you will see a notch out of it.
That's where the spring holder is.
I use a jewellers screwdriver and at the same time I press against the keeper towards the seat, I pull slightly on the ****> Don't force it, it slides right off.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
I think I was missing the release spring when trying to remove the ****. I'll try it again And I think I'll get it now. Sometimes the smallest thing can relly hold up a project.
Herdsman
