Turbo time???????
Old Feb 10, 2005 | 11:08 PM
ccg's Avatar
ccg
Turbo time???????
o.k. I'm taking my truck to the shop to get it checked out. What is a good compresion number for a turbo? Don't want to blow it up.
Thanks,
CCG
Old Feb 10, 2005 | 11:20 PM
89ford73's Avatar
89ford73
are you talking about compression ratios? the stock idi's have 21.5-1 compression ratios, but if you want to add a turbo, you need a lower compression ratio the powerstrokes have a 17.5-1 ratio, and they will hold up to 30 psi boost easily. the stick 21.5-1 ratio of the idi will hold up to about 15 psi boost. what do yuo mean you are taking it to the shop and having it checked out??? what's wrong with it?
Old Feb 10, 2005 | 11:24 PM
ccg's Avatar
ccg
There is still a big smoking issue. but more important I am worried about a worn out motor not being able to handle boost.thanks ccg
Old Feb 10, 2005 | 11:31 PM
cemenacho's Avatar
cemenacho
I'd be concerned with how many miles the truck has on it and wether it's worth it or not at this point to invest $2-3K on a turbo setup
Old Feb 10, 2005 | 11:34 PM
89ford73's Avatar
89ford73
my motor has 340,000 miles on it, an i just ut a turbo off 5.9 cummins on it. i make 15 psi boost and run her at 4,000 rpm's alot. i also have 4.10 rear which means the motor has turned considerably more than a more common diesle with 3.55's your motor can't be worn out bad enough that a turbo will effectively shorten the life of the motor. if it don't bang and clang, it will be fine
Old Feb 11, 2005 | 09:54 AM
ditto's Avatar
ditto
those engines were made to be turboed in more ways then one, it stucks that ford didn't put them in.......I want to turbo mine, but it'll be 3700 bucks in Azusa to get a turbo from Banks installed
Old Feb 11, 2005 | 10:10 AM
cemenacho's Avatar
cemenacho
I'd get the ATS turbo anyway, but would not put $3700 into a truck that old (unless money is no object). save your money for a powerstroke.
Old Feb 11, 2005 | 06:42 PM
ditto's Avatar
ditto
The ATS turbo is a sweet setup as well, plus it fit's better. However getting one in sol california is completely a different story due to the fact that the Banks HQ is here in Azusa. And to be honest i plain on putting that much into the truck, the powerstokes are nice but, i like my truck and it only has 120k miles .
Old Feb 11, 2005 | 10:12 PM
RawPower's Avatar
RawPower
Love will never be replaced by HP...
You should just do it yourself, its not hard.
Old Feb 12, 2005 | 04:14 AM
ditto's Avatar
ditto
hehe you know it! But to be honest I watched a step by step photo installation of it and i don't want to do it. I would be afraid to even touch it :-/
don't get me wrong i enjoy working on my truck but this is much to major for my skills.
ccg711
Jul 7, 2009 06:29 AM
ccg711
22
Jun 3, 2009 09:45 PM
ccg
16
Jan 8, 2005 05:11 PM
ccg
Dec 10, 2004 11:29 PM
