FI302 TO CARB/
Old Feb 10, 2002 | 03:53 PM
porkchop's Avatar
porkchop
FI302 TO CARB/
WITH ALL IN HAND HOW MUCH TROUBLE WOULD IT BE TO CHANGE FROM FI TO CARB I KNOW THAT I WILL NEED TO CHANGE OUT THE INTAKE BUT WHAT OTHER THINGS DO I NEED TO THINK ABOUT?
Old Feb 10, 2002 | 06:13 PM
desperado_18_2000's Avatar
desperado_18_2000
FI302 TO CARB/
Changing the intake is the first part of it, after that you need a fuel pressure regulator because the electronic fuel pump is way too much for a carb. i don't remember the psi its supposed to operate at...but you need one of these...then its just pretty much bolt everything on, and go cruising.
Old Feb 10, 2002 | 07:33 PM
porkchop's Avatar
porkchop
FI302 TO CARB/
Thank you sounds pretty stright forward,
Old Feb 10, 2002 | 10:24 PM
Franklin2's Avatar
Franklin2
FI302 TO CARB/
What about the transmission linkage if it's an automatic?
If it's a late model with an electronic trans, what's going to tell the tranny to shift correctly (no throttle position sensor)?
You have to get a new older type distributor so the timing will be controlled correctly. This means wiring a new eletronic ignition box.
Old Feb 10, 2002 | 11:43 PM
porkchop's Avatar
porkchop
FI302 TO CARB/
never thought of the tranny it's and 85 will i need to change that out? As for the distributor I'm thinking of changing over to a One piece ignition with the coil and module inside the cap like the chevys pretty easy set up one wire. Thanks for all the help I'm getting here I'm sure I'll be back in a day or two for more help.
Old Feb 11, 2002 | 02:05 PM
Franklin2's Avatar
Franklin2
FI302 TO CARB/
If it's an 85, it might be an AOD(does it have overdrive? In this case you would just need to hook the linkage up correctly.
Old Feb 12, 2002 | 10:07 PM
porkchop's Avatar
porkchop
FI302 TO CARB/
yes the tranny is an over drive and it's a 1985, so what do you mean when you say just hook up the linkage correct?
please let me know because I'm starting to change my mind about doing all this and buying a nother truck 89 f-250 4x4 this is what is making me think
Old Feb 16, 2002 | 04:12 PM
Dmaas17's Avatar
Dmaas17
FI302 TO CARB/
the linkage they are talking about is the T.V. linkage (throttle valve) it moves with the throttle plates to schedule when/how the transmission shifts. I had a holley 600 4bbl. and bought a kit from summit raceing for around 40 bucks. look at the bauman engineering web site (forgot the www address) they explain how to do this. if you dont hook up the T.V. linkage it will drive poorly for about 2 blocks and then weld the clutch packs together. but dont be scared to do this. just read up on the subject before you tear into the project and you will get great results.
Old Mar 4, 2002 | 06:33 PM
86F150PAT's Avatar
86F150PAT
FI302 TO CARB/
I CURRENTLY HAVE AN 86 I JUST DID THIS....I AM HAVING SHIFT PROBLEMS.....DID YOU GET IT DONE? PLEASE HELP...THE TRUCK RUNS AWESOME....SHIFTING SUX...HELP.
Old Mar 4, 2002 | 10:45 PM
Franklin2's Avatar
Franklin2
FI302 TO CARB/
Here is the link to the transmission linkage adjustment.
http://www.baumannengineering.com/tvlnkage.htm
Old Mar 5, 2002 | 12:47 AM
intelsldr's Avatar
intelsldr
FI302 TO CARB/
