Modular V10 (6.8l)
engine problems 2000 f250
Old Feb 10, 2005 | 08:06 PM
jessejamz's Avatar
jessejamz
hey guys hope you can help
i have a f250 with of course a v10.. heres my problem. i just had a iginition coil replaced because the service engine light was on, and the truck was running kinda sluggish, seemed like it wanted to bog down as it was being driven.. well the dealer repaired it and it still is running bad,(no light now) even at idle it bogs down but continues to run.. escpecially bad at around 40-45 mph when rpms are fairly low(computer shows no codes)...i just bought a new set of plugs thinking that might do it, but thought i would ask the pros here first....
anyway im a body guy im "engine" stupid
thanks in advance
Old Feb 10, 2005 | 08:24 PM
V10KLZZ71S's Avatar
V10KLZZ71S
My first thought would be the fuel filter,or possibility of the fuel pump getting weak.I would try the fuel filter first if you haven't already. also i have seen the inj wires get a small break in them killing that cyl.
Old Feb 11, 2005 | 03:02 AM
NoMo's Avatar
NoMo
I think you're on the right track as a bad coil can lead to a fouled plug or even a clogged cat. Fuel filter is a cheap place to start and sure won't hurt anything though!
Old Feb 11, 2005 | 12:55 PM
jessejamz's Avatar
jessejamz
ok, i will change plugs today and go get a fuel filter to, i was also told that the cat conv. could be clogged also(good call)... i will also cut it off and see if his helps...thanks guys illl let ya know
Old Feb 11, 2005 | 01:18 PM
NoMo's Avatar
NoMo
I would try one thing at a time... that way you'll know what actually fixed the problem.
Good Luck!
Old Feb 14, 2005 | 05:26 AM
Crown Man F250's Avatar
Crown Man F250
Jesse-- I Just Got Done Fixing The Problem And It Was Interesting. I Took Out My Mass Air Flow Senor (behind Filter) And Cleaned It With Crs Air-intake Cleaner(let It Dry Befor Installing). Then I Took Off My Throttle Body And Cleaned The Heck Out Of It And The Idle Air Control Also (attached Behind) If Yea Dont Want To Take Body Off The Other Way Is To Take Air Intake Off And Spay Into Body. The Crs Air Intake Cleaner Tells U On Back How To Do. It Works Great. Can Buy At Local Parts Store (auto Zone)
Any Questions Get Back
George
Old Feb 23, 2005 | 10:49 AM
jessejamz's Avatar
jessejamz
no fix
well finally got around to working on my truck...i changed plugs,filter, went ahead and replaced cat conv. , used a top end engine(induction) cleaner (spray type)have no loose or cut ign coil wires.. still have problem.. guys im lost on this... any more ideas????
Old Feb 23, 2005 | 12:15 PM
Crown Man F250
Jesse-- When the Mass AirFlow Sensor gets dirty, it will make the PCM think Different. The Sensor regulates the air flow-fuel mixer and tells the PCM how much fuel to deliver out of the injectors. I Have seen this where too much fuel is delivered or not enough fuel. My V8 was throughing codes on 2 coils misfire so i replace the coils but no fix - I cleaned the MAS and put the old coils back in and it fixed the problem
Try cleaning the Mass Air Flow Senor (behind Filter) And Cleaned It With Crs Air-intake Cleaner(let It Dry Befor Installing).
Old Feb 23, 2005 | 01:53 PM
jessejamz's Avatar
jessejamz
crown man-wouldnt the top end induction cleaner i sprayed worked on cleaning the mass air flow sensor?
Old Feb 23, 2005 | 02:39 PM
Crown Man F250
[QUOTE=jessejamz]crown man-wouldnt the top end induction cleaner i sprayed worked on cleaning the mass air flow sensor?[/QUO
Jesse my bad - all those cleaner out there are about the same. u can use that but be sure when u spray onto it keep the can far back. less the pressure on the sensor the better. spray across sideways, up&down. Let the senor air dry.
any problems get back
Old Feb 23, 2005 | 07:35 PM
85capr's Avatar
85capr
did you replace the plugs before you did the top engine clean, because that can foul out your plugs if you did.
Old Feb 24, 2005 | 05:54 AM
NoMo's Avatar
NoMo
MAF sensor is down by the air filter- so it's doubtful that you got it cleaned when you did the top-end. Just use a cotton swab (Q-tip) and some rubbing alcohol. Be careful not to damage the sensor.
Old Feb 24, 2005 | 07:33 AM
jessejamz's Avatar
jessejamz
i changed the plugs after the clean, but i will clean the mass air sensor and let you guys know... thanks guys
cjdmcgarry
Aug 25, 2014 10:11 PM
75_F150_mudtruck
Sep 26, 2013 09:41 PM
bmxgeorge
Jan 25, 2012 08:41 PM
95F150MTR
13
Jul 28, 2010 10:21 AM
jakefreeman78
Jun 30, 2008 12:21 PM
