Entire Dash does not Light up??
Old Feb 10, 2005 | 08:39 AM
123svt's Avatar
123svt
Well my wiring in this truck is all messed up, my entire dash doesn't work, none fo the lights in my dash work but all the gauges work, so at night im kind out of luck when I speed.. ..Is this normal?...thanks
Ryan
Old Feb 10, 2005 | 10:23 AM
texan2004's Avatar
texan2004
No its not normal but the bulbs do have a tendency to burn out. di this happen all of the sudden of did you lose section of the dash lighting one by one?
Old Feb 10, 2005 | 11:40 AM
123svt's Avatar
123svt
I bought the truck during the day once it became night I was like what the heck...none of it works, none of teh fan/air control
87 XLT's Avatar
87 XLT
Take a look at the fuse page in your owners manual and check the fuse.
Old Feb 10, 2005 | 11:42 AM
D-ranged2.5's Avatar
D-ranged2.5
You know, it might just be the wiring. Mine is bad... I'm missing about half of my dash lights, but all the gauges work. One of the lights actually came back on when a friend of mine smacked the dash a lot. So I don't think it's the bulbs, unless they're loose. You'll probably need to fix it though, won't you? I don't know how to do that, but I'd think if you don't already know it, it's better not to learn on your primary vehicle...
Edit... my oil pressure gauge is a little funky, but it still works... eventually.
Old Feb 10, 2005 | 12:07 PM
PW01's Avatar
PW01
I just lost a gage light 2 days ago, the bulb size is 194. I haven't pulled the dash to fix it, but will soon. D-Ranged2.5, your problem is your oil sending unit. Mine did the same thing, and that fixed it. Apparently, its a pretty common problem.
Old Feb 10, 2005 | 01:33 PM
texan2004's Avatar
texan2004
These bulbs are located in a fitting that 1/4 turns into the back of the instrument panel. The panel has a printed circuit on the back, no wires. When you get it off you will see what I mean. As far as the Oil gauge goes, there are a number of threads here that discuss this problem and the culprit is usually a bad sending unit. The instrument panel is not that bad to get out and the bulbs are very easy to replace once the IP is out.
I agree with 87 XLT though, check your fuses first expecially if all of the lights are out.
Old Feb 10, 2005 | 02:08 PM
Dave257's Avatar
Dave257
Also remember that it could be in the dimmer/light feed to the dash. What year truck and maybe we can be more of more help.
Dave
Old Feb 10, 2005 | 11:03 PM
123svt's Avatar
123svt
1994 Mazda B2300
Old Feb 11, 2005 | 02:03 PM
pawpaw's Avatar
pawpaw
I like Dave257 & 87XLT's take on this. If everything is out, seems to me it's not likely ALL the lamps would be burned out. So make shure the dimmer for the instrument lights isn't turned all the way down, as Dave suggested. Then if that checks out ok, inspect the instrument lamp fuse, as 87XLT suggested, I'd add, don't just look at it, test it with an ohm meter for continuity. If that checks out ok, do a voltage check at the fuse B+ input contact. If that checks out ok, then check the ground point for the instrument lights. If that checks out ok, then the problem lays between the fuse panel & the ground at the circuit board, so you'll just have to do a votage check from the output of the fuse pannel, step by step, to the circuitboard. Pay close attention to the condition of the wires, electrical connectors & the pins, sockets & their wire crimps. Look for crimped or cut wires bent, broken or pushed back pins or sockets, or faulty wire crimps to those pins & sockets, or even a bad solder joint at the circuit board. Let us now what you find.
Old Feb 11, 2005 | 05:09 PM
123svt's Avatar
123svt
Alright We Will See What Happens Tonight, Thanks
Old Feb 11, 2005 | 06:13 PM
Dave257's Avatar
Dave257
Check fuses 11, 10, and look at 13 as it feeds the dash lights, control lights, ashtray light and radio lights.
Dave
