89 F250 starting problem
Old Feb 27, 2005 | 08:46 PM
broken wire's Avatar
broken wire
knowak, If you have acess to a computer unit, go ahead and give it a try. The way I test my electronic problems though is not through ohms unless power and grounds are not available, I do all of my testing through voltage drop, it is a more definite way of testing automotive electronics than ohm testing, and also for this vintage Ford, I use a Breakout Box for this style PCM component, wiring, power and ground testing. You can also backprobe using pins into the back of the components instead of pinching into the wiring. As for the grounds, I just tested a Ford 60 pin computer on the bench, pins 40 and 60 are connected to pin 46 in the pcm, pull your computer out of your vehicle, set your meter on low ohm scale, probe pin 40 with one probe and pin 46 with the other probe, should be "0". Next probe pin 40 to 60 and 46 to 60, all should be "0". I don't think you have to mess with pin 20 at all. I believe from what I am reading from your replys, this is going towards a computer failure. Take the covers off of your computer and look at it under a magnifying lens, look for a burned spot, you may be able to thread and solder a small piece of copper wire across a burned area, (if that is what it is). Been there, done that. Broken Wire
Old Feb 28, 2005 | 09:42 PM
knowak's Avatar
knowak
Smile Problem solved!
Sure enough, it was the computer. Many thanks to everyone here who added their much appreciated input!
RPetty_43
Sep 22, 2016 11:34 AM
mmackson
Aerostar
Aug 16, 2015 11:07 AM
greystreak92
1978 - 1996 Big Bronco
15
Apr 16, 2013 09:41 PM
greystreak92
Mar 6, 2011 11:16 AM
Stephen Tangalin
Jul 25, 1999 10:40 PM
