Sponsored by: Kumho
4" lift question
Old Feb 9, 2005 | 12:23 PM
yeha4x4's Avatar
yeha4x4
4" lift question
Hi I would like to lift my76 f150 4x4 but I noticed some kits say that I may need longer driveshafts. Anyone have any exp with this? By the way it is a longbed.
Old Feb 9, 2005 | 02:10 PM
ivanribic's Avatar
ivanribic
With a longbed you should not need to touch your rear driveshaft. You MAY need to lengthen the front but you will not know this until you do the lift. A lot of times you'll have enough room in the slip joint to accomodate the lift. If not it typically costs around $100 to have a shaft lengthened a few inches.
Old Feb 9, 2005 | 08:07 PM
chuck641's Avatar
chuck641
when i lifted my old '77 f-150 4" i didn't need to do anything with either driveshaft. you should be fine with just the suspension kit, but like ivan said you will know once its on
Jason
Old Feb 11, 2005 | 01:09 PM
yeha4x4's Avatar
yeha4x4
Thanks for your help, Now all I need is to pick a brand.
Old Feb 11, 2005 | 01:11 PM
yeha4x4's Avatar
yeha4x4
one more question, How much room in the slip joint do I need to maintain?
