Grill Question
Old Feb 9, 2005 | 01:19 AM
awsomefords's Avatar
awsomefords
Question Grill Question
Hello everyone,
My question is...will a grill from an erlier 70's truck fit on a 78? Just wondering cause I like the older look.
Thanks -Mike-
Old Feb 9, 2005 | 01:40 AM
FordPickup460's Avatar
FordPickup460
73-79 Shells are interchangeable. 73-77 Inserts are interchangeable. A 72-earlier grill or a 80-newer grill will not fit.
Old Feb 9, 2005 | 09:53 AM
ivanribic's Avatar
ivanribic
But keep in mind that you will probably need to switch headlight buckets as the earlier grills had round headlights and the 78/79's had rectangular headlights. SOME 78's had round headlights but the headlight bucket itself is up too high so you'd still have to reposition it.
Old Feb 9, 2005 | 11:26 AM
awsomefords
Hey Everyone,
Thanks for the help you definitly answered my question.
Old Feb 9, 2005 | 11:40 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
thats good to know, ive been thinking about putting a 76 grill on my 78, i didnt think that the lights might be positioned differently.......i just assumed they were the same, learn something new everyday..........
Old Feb 9, 2005 | 11:44 AM
highboy1975's Avatar
highboy1975
if you look at the 78-79 trucks, the headlight is almost right below the hood. on the early years, therers the turn signal in there too, puts the light probably 4 inches closer to the bumper. well, id guess minimum 2 inches, and a max of four without them side by side to measure.
Old Feb 9, 2005 | 02:08 PM
ivanribic's Avatar
ivanribic
I found this out when I lifted my truck. With the later model grill the headlight sit way too high to meet the 54" national limit . . . they're at about 59" right now. When I swap grills they'll be right at 54". So there's a little tip for anyone wanting to get away with more lift legally.
Old Feb 9, 2005 | 02:52 PM
SwOkcOffRoader
what grill are you going with?? im rather fond of the grill on my 76 F-150(pic in gallery) i think its the best one out of the 73-79 grills, but thats just my opinion..........
Old Feb 9, 2005 | 03:24 PM
ivanribic's Avatar
ivanribic
I'm constantly collecting parts so I have inserts for the 73-75 and the 76/77's. I'll probably go with the 73-75 style. I think they look evil on a big truck. The grill shell is the same for both and the headlight position is the same so I can change the inserts in a matter of minutes if I want a different style.
Old Feb 9, 2005 | 07:43 PM
Poulsom's Avatar
Poulsom
I have a 1974 with a 1979 cab and frone clip and I put in a 1974 grill. One thing you will have to do is make 8 oval adjusting holes to mount the brackets for holding the round headlights. Other than that it should go together. Mine is not complete yet because the truck is a major restoration project. If you find anything else you need to change post it so I know what I will have to do in order to cross that bridge when I get to it.
Old Feb 10, 2005 | 08:56 AM
FarmboyAC's Avatar
FarmboyAC
I have a 78 with the 79 grill style in it and i was wondering if that was factory with the late 78's or if sombody had changed it before i got it. Thanks, Derek
Old Feb 10, 2005 | 09:27 AM
73Custom's Avatar
73Custom
Some '78s had round headlights and some had rectangle. The base model 'custom' had round ones while the better equipt 'ranger' and 'xlt' had rectangle.
Marty
