Ok guys help me with my spring codes. I have read the faq's section and I cant seem to match that with what is on my placard. It reads SPR and under it has the code TTPP what is this exactly? My truck is a 2004 Crew Cab V-10 4x4.
Sorry Stew, I don't have anything on the 2005's coils yet. So T could be a 5200 lbs coil on a 4x4 truck. As far as the rear springs are concerned, there are 7 different leaf springs available in the 2005 BBA books:
So most likely you have a 6100 lbs rated spring pack if you only have 5 leaves or a 7000 lbs rated spring pack that has 6 leaves including the auxillary spring. The auxillary spring is easy to spot, you'll know if you have it. Here's what it looks like on my 2003, the top leaf with the yellow sticker is the aux spring:
I got this from a ford spec book, this is all they have... (i.e., nothing for the rear)
Springs codes are listed as a two-part code. The
first character listed is for the front springs. The
second code listed is for the rear springs. Auxiliary
rear springs may also be listed.
Front Springs - F-Series
o E - F81A-5310-EA
o F - F81A-5310-FA
o G - F81A-5310-GA
o H - F81A-5310-HA
o I - F81A-5310-RA
o 2 - Five-speed manual, F-Series o J - F81A-5310-JA
o 5 - Six-speed manual, Dana ZF (S6-650), o K - F81A-5310-KA
F-Series
o R - F81A-5310-AAB, 3,600 lb.
o 7 - Six-speed manual, Dana ZF (M6HD-W),
o S - F81A-5310-AAB, 4,000 lb. F-Series (diesel)
o T - F81A-5310-ABB, 4,400 lb.
o U - F81A-5310-ACB, 4,800 lb.
o V - F81A-5310-ADB, 5,200 lb.
o W - F81A-5310-AEA, 5,600 lb.
o X - F81A-5310-AFA, 6,000 lb.
o Y - F81A-5310-VA
o Z - 2C34-5310-WA
Front Springs - Excursion
o B - YC35-5310-ABC
o C - YC35-5310-ACC
o D - YC35-5310-ADA
o G - YC35-5310-GA
o H - YC35-5310-HA
o S - YC35-5310-SA
Rear Springs - F-Series
o B - 3C34-5560-L
o C - 3C34-5A975-D
o D - 3C34-5A975-G
o E - 3C34-5A975-K
o J - 3C34-5A975-J
o M - 3C34-5A975-E
o N - 3C34-5A975-F
o P - 3C34-5A975-C
o S - 3C34-5A975-C
Rear Springs - Excursion
o A - YC35-5560-A
2004 Excursion, F-Super Duty 250-550, 8/2003
my spring code is L5F everyone ive asked has no idea what i got for springs the truck is a 94 F250 4.9l Anyone seen or no what rear springs i got ? Thanks for the help guys
