Sponsored by: Auxito
coolant system flush
Old Feb 8, 2005 | 03:06 PM
jason86's Avatar
jason86
Whats the best way to flush the cooling system on a '97 F-150 with a 4.6L V8?
Thanks
Old Feb 8, 2005 | 04:56 PM
MBDiagMan's Avatar
MBDiagMan
Drain the radiator using the drain valve at the lower right rear of the radiator and then drain the block using the plugs just above the oil pan rail on both sides of the engine. Don't loosen the main bearing cross bolts, rather it is a pipe plug on each side of the block.
Fill it with water, run just a little and then drain that. Repeat until you are draining water that is absolutely clear, the close everything up and fill with a 50/50 mix of water and antifreeze.
Good luck,
Doc
Old Feb 9, 2005 | 07:19 AM
jason86's Avatar
jason86
Thumbs up
Thanks alot
Old Feb 10, 2005 | 11:21 PM
bambishooten's Avatar
bambishooten
is the 2001 4x4 Screw the same?
rawdeal
Mar 30, 2014 05:44 PM
jl4407
Aug 5, 2012 01:34 AM
Gage2502
Jun 20, 2012 06:40 PM
big dirty
Sep 13, 2011 05:19 AM
BobFlowers
1983 - 2012 Ranger & B-Series
Sep 24, 2002 10:04 AM
