rear window wiper not touching
Old Feb 8, 2005 | 12:08 PM
carfreak113's Avatar
carfreak113
My rear window wiper is not touching the glass on the first half of its run.. I watched it move back and forth for a while and it doesn't seem bent. When I bend the arm closer to the glass it will touch it for a while but then go back the way it was. Is the motor not completely aligned or the arm that bent? The wiper blade is new.
Old Feb 8, 2005 | 12:51 PM
ford97sohc's Avatar
ford97sohc
I'm having the same problem...I don't know how I can get the top portion of the wiper to touch the glass.
Old Feb 8, 2005 | 01:02 PM
stunod2002's Avatar
stunod2002
I have that problem as well.. I was thinking of using a smaller blade. I think it has a 15" one now, I am going to try a 14" or 13" one.
Old Feb 8, 2005 | 02:07 PM
Backin72's Avatar
Backin72
I had the same problem too. I took the rear wiper off and noticed there was a lot of sand and crud around the spring in the arm. I cleaned it out and it helped a bit but it still didn't wipe correctly. I went to the local Canadian Tire store and bought this item: http://www.surewipe.com/en/index_800x600.htm
Worked great!
Old Feb 8, 2005 | 02:16 PM
PrtclMn001's Avatar
PrtclMn001
I have been having the same problem for some time...
Old Feb 8, 2005 | 03:01 PM
ajguzik's Avatar
ajguzik
Thumbs up
A fairly weak spring holds the blade against the glass. Any crud that seeps between the moving parts weakens the spring's effect to hold the blade in place. i use a lubricant like LPS2 to clean out the mechanism and to lubricate. Back the spray against a rag and wrap the base of the arm in a clean rag for a while to keep drips off the finish. Lots of salt spray in certain snowy climates finds its way into the linkage. Give the glass window linkage in the tailgate section a couple shots of LPS2 while you're there. This stuff is great on the garage door rollers too.
Old Feb 8, 2005 | 03:56 PM
1081's Avatar
1081
There are other threads on here like this. I fixed it the way the dealer told me to, I carefully bent the wiper arm slightly so that it touches the glass. It has worked for three years.
Old Feb 8, 2005 | 04:09 PM
stunod2002's Avatar
stunod2002
Yea, I tried that at first. Now not only does the top tip not make contact, but the middle only makes contact on the back swing.. Kind of annoying. I am still hoping the smaller blade will work.
Old Feb 8, 2005 | 05:45 PM
Backin72's Avatar
Backin72
If you can get one of these, http://www.surewipe.com/en/index_800x600.htm they really do work. I'd do that before going to a smaller blade.
Old Feb 8, 2005 | 09:26 PM
carfreak113
Thinking about that product(my local parts store didn't carry that or anything similar) I guess I could shorten the spring inside the wiper arm. That in theory would force the arm to stay closer to the glass.? 1081 with what did you bend the arm and how much did you actually bend it? When I tried bending the arm it worked for a very short while but went back to what its currently doing.
Old Feb 8, 2005 | 10:11 PM
Buzzman222's Avatar
Buzzman222
i have same problem on 97 explorer sohc.......I bent the arm....Stuck it in the vice and Slowly added a curve to it on the top half only adding A LITTLE bit of a bend but i bent it evenly not just in one spot.Works better then ever now.
Your problem might be you bent it to much to close to the top.
I like that surewipe product might buy one when this wiper wears out.
Old Feb 9, 2005 | 07:43 AM
Golfmore's Avatar
Golfmore
I bent the arm in two places, then ground the ramp part of the blade rest that is fixed below the glass. All is well now.
Old Feb 9, 2005 | 11:48 PM
dybeepvw's Avatar
dybeepvw
I lubricated the hinge/elbow with teflon spray; soaked it good and it touches the window all the way now.
Old Feb 10, 2005 | 01:03 PM
carfreak113
I bent the crap out of the arm and put a 13" blade on there and now it works perfectly. It just doesn't fit in the little bracket under the window now..
Old Feb 10, 2005 | 04:06 PM
1081's Avatar
1081
I bent it a pretty good amount, I would bend it a little, try it then bend it again etc. I didn't put a longer blade on it and don't know if that would keep it from hitting the parking block. I know mine makes more noise as it his the block now. You might try bending it back out a little at a time until you still get good coverage on the glass and it parks in the block.
john jamieson
Apr 5, 2017 04:28 PM
rsylvstr
1997 - 2003 F150
Mar 12, 2016 08:11 PM
James888
Mar 1, 2016 05:59 PM
makthenif
Sep 18, 2012 06:56 PM
hawk1snest
Feb 24, 2012 02:10 PM
