Tires
Old Mar 18, 2002 | 08:51 PM
Shannonm1's Avatar
Shannonm1
Tires
Would snow tires on the rear cause more rolling resistance and worse fuel milage??
I have a '84 F-150 w/ 351W & C-6, only getting abot 6-7 Mpg.
Just replaced the motor and rebuilt the carb. Same milage before and after. I'm not sure what to check next. Thanks for any help.
Shannon
Old Mar 19, 2002 | 12:28 AM
canadianfordman's Avatar
canadianfordman
Tires
I dunno, but my 84 F150 351w c6 gets about 9 and I drive it hard. So that gives you something to compare to.
Old Mar 19, 2002 | 12:40 PM
Cope's Avatar
Cope
Tires
it's been my experience that adding rougher tires (same size as previous set) of course does slightly decrease gas mileage, due to the added rolling resistance like you said. I would guess your gas mileage problems are coming from somewhere other than tires if it is that low, unless you have oversized tires. What size are you running?
-Cope
95 F-150 4x4
4.9L M5OD
Front Truetrac Rear Detroit
3.73 Precision Gears
Warn Premiums
4" Superlift Superunner
Old Mar 19, 2002 | 04:26 PM
Franklin2's Avatar
Franklin2
Tires
I have also heard snow tires are usually made of a softer compound and won't have the tread life of a regular tire.
Old Mar 19, 2002 | 08:14 PM
Shannonm1's Avatar
Shannonm1
Tires
Right now it has 235/75 R15 on it.
Old Mar 20, 2002 | 02:45 AM
RedRanger1983's Avatar
RedRanger1983
Tires
You could try replacing your fuel filter, and of course, a tune up (plugs, wires, cap, rotor), and airfilter.
Old Mar 20, 2002 | 10:33 AM
rocky's Avatar
rocky
Tires
If you changed to another tire size you will have essentially changed your gear ratio in the process.
Old Mar 23, 2002 | 10:54 AM
rcdague's Avatar
rcdague
Tires
I am a commercial tire dealer and retreader, so I know of what I speak. Snow tires are made of a softer compound, this provides better traction in both wet and dry conditions. They will not wear well during the warm parts of the year and should be taken off when winter is over. Snow tires do have quite a bit more rolling resistance than all seasons and the rolling resistance goes up as the tire gets warmer. Whether they get warm because the weather is warmer or because you are driving down the highway heating them up.
Old Mar 23, 2002 | 02:17 PM
canadianfordman
Tires
rcdague, I am pretty sure I know the answer but do bigger tires with Mud tread and such have softer rubber there for they will wear down a lot faster? Thanks.
Old Mar 23, 2002 | 06:39 PM
Mil1ion's Avatar
Mil1ion
Tires
