Cleaning your PSD engine?
Old Feb 8, 2005 | 10:58 AM
kmartin's Avatar
kmartin
Hey everyone -
Sorry if this has been posted before, been searching but cant find a thread re: cleaning your PSD engine.
can you pressure wash, steam cleans these engines?
Any recommendations? I've heard foamy engine bright is good. Any thoughts?
Thanks - kmartin
Old Feb 8, 2005 | 11:15 AM
ckal704's Avatar
ckal704
I have seen in these posts that something like Simple Green and low pressure water are ok.
My only suggestion would be to keep the water off of electrical components. I keep coming back to my Injector Driver Module situation, but the tech at the dealership said that water likely got down the backside of it and entered the vent in the back of the module and caused it to malfunction. This was on a 97 and Ford has since relocated the unit because of this potential problem. They are about $850 new, so you definitely don't want to do anything that can damage them.
I don't know what year truck you have, but if it is a 97 or older PSD, your IDM is located on the drivers side fender underneath the hood spring area. It is silver and about the size of a hardcover book.
Since I replaced mine, I ran a bead of gutter sealant across the top edge and down the aft edge of the unit. The vent is on the connector end (nearest cab) of the unit. That should keep anything from trickling down to where it can get into the vent.
Old Feb 8, 2005 | 12:26 PM
BadAss01F250's Avatar
BadAss01F250
i have a 01 f250 7.3.....just grab about 4-5 cans of engine brite, spray it on and let it set for about 10-15mins the wash it off with your garden hose, works great
Old Feb 8, 2005 | 12:31 PM
Robbgt's Avatar
Robbgt
yep simple green and a low pressure power washer qork great!! avoid the area around the turbo as well as the electrical, (obviously the air intake as well!!)
truck_guy's Avatar
truck_guy
just make sure the engine is cold, steam has no problem finding it's way into electrical components.
