How long should it take to warm up inorder to drive and not stall. It stalls until it warms up. Could take 4 or 5 minutes or even longer in real cold. Once warmed it runns fine. Its a 2000 7.3 automatic. It has about 35k miles. It has new fuel and air filters. The temperature here is in the thirties and below.
i dont know if this would couse it....but are you running 15w40 still?? since its so thick it could cause it to stall and run rough until it thins out by heat
Whenever one of the engines stalls out, the CPS is typically the first suspect. As a shot in the dark, if you have a spare CPS, I would try installing it and see if that cures the problem. If you don't have a spare CPS, I would reccomend you buy one and carry it with you.
wow, 30 to 40 degrees? i thought it was colder, but since its not that cold, id have to go with what clux said, try another CPS out and tell us how it is
