It's running like crap!!!
Old Feb 8, 2005 | 07:42 AM
PrtclMn001's Avatar
PrtclMn001
And, once again, my check engine light is on.
I go to give it gas, it hesitates, then kicks in. When I stop at a light, it idles at about 500 RPM and runs like crap. Any ideas??
2001 Mountaineer... 5.0 litre... AWD... sorry... forgot to put that in before..
Old Feb 8, 2005 | 12:02 PM
carfreak113's Avatar
carfreak113
Got any codes for the CEL? Also are sure you have no vacuum leaks anywhere?
Old Feb 8, 2005 | 01:30 PM
PrtclMn001's Avatar
PrtclMn001
I pulled the air filter box... if I put even two fingers in front of the intake (barely blocking it) it dies.
haven't been able to get to Autozone to get the codes pulled...
any thoughts?
Old Feb 9, 2005 | 09:48 AM
tony b.'s Avatar
tony b.
Exclamation
Yeah should definately go to auto for the codes i took mine yesturday they told me tune up ,pcv valve,carbon build up & iac replacement Ill give a try & let ya know if worked mine run like crap in the morning f it is brutely cold-98 explorer spt. trac
