ford build sheet ?
Old Feb 8, 2005 | 06:53 AM
94f2507.3td's Avatar
94f2507.3td
ford build sheet ?
i recieved my build sheet today for my 76 f250 360 4spd 2wd but i have a? here is vin f26yka52957 ford says its a 4x4??? here is thier brake down f26 f250 pickup 4x4 y 360v8 2v k kansas city plant a52957consecutive unit #. well the truck is 2wd i belive from factory as i cant see any mounts where a solid front axle would mount! any help on figureing this out would be appreciated thanks
Old Feb 8, 2005 | 07:17 AM
Gregg C.'s Avatar
Gregg C.
Did you check the VIN on the frame? See if they match. Someone could have swapped the door or cab from the 4x4?
Old Feb 8, 2005 | 07:22 AM
94f2507.3td
only the 3rd owner of this truck and dont think it has been in wreck or anything everything else on build sheet is correct color ect. it also doesnt say on build sheet but it has a/c i guess it was dealer installed
Old Feb 8, 2005 | 08:45 AM
hawkrod's Avatar
hawkrod
F26 on the serial number means that number is from a 4X4. I would go looking for that frame number, you could have a stolen truck with a switched tag. Seen it more times than you want to know. Hawkrod
Old Feb 8, 2005 | 08:53 AM
94f2507.3td
where is vin at on frame ,will check asap it is raining out now? how hard to convert to 4x4 if i wanted to??
Old Feb 8, 2005 | 10:02 AM
missalot's Avatar
missalot
The VIN on the frame is stamped on the top of the passenger frame rail. On my '78 it was about even with the front of the block.
Conserv
Oct 26, 2014 03:23 PM
F2501972
20
May 28, 2014 09:19 AM
tschrubb
Jul 23, 2011 08:34 PM
onebad40willys
Apr 7, 2001 09:26 PM
