my 2004 6.0 still leaks after fixed, it hadnt leaked, 5k miles later it leaked again i looked at 05 6.0 and they still leak.........??? Anyone know why they leak cause i really wouldnt want to switch to a crappy duramax, or cummins.
Does it have just the wet spot on the bell housing or is it leaving a little puddle on the driveway? I had a second RMS put it, both in the first 10,000 then it has been ok. 33,000+
there is a bulletin on this that it is over greased pilot bearing ask your dealer about this i had the same problem if you want i think i still have the bulletin from
