2002 explorer o\d light flickers
Old Feb 7, 2005 | 08:05 PM
stewart19777's Avatar
stewart19777
My buddies mom just bought a 2002 explorer. its been running fine but now the Overdrive light just flickers and wont go on or off. I makes the tranny shift really hard. It doesnt do it in any paticular gear just when ever. Any body had this prob any advice would be helpful. It still goes in to over drive just shifts hard. its a 4wd model i think its the 4.6 (not positive). thanks
Old Feb 8, 2005 | 01:22 AM
AlfredB1979's Avatar
AlfredB1979
Get it checked out. That's a pretty pricey piece of the rig to ignore.
If there is a code, that's a step towards a solution.
Old Feb 8, 2005 | 11:00 AM
stewart19777
not sure how you check the codes. was wondering if it was just the sensor or switch on the tranny or if may be it was low on fluid checked it seemed like it was full
Old Feb 12, 2005 | 10:08 AM
chazglenn3's Avatar
chazglenn3
The flashing O/D light is an indication that the computer has set a DTC code. You need a code reader to check the codes. When the tranny has set a code, it goes into a "fail safe" mode, and that is what is causing the hard shifts. Take it to your local Autozone and they will check the code for you.
Charles
Old Feb 22, 2005 | 08:04 AM
edward r's Avatar
edward r
Mine is doing the exact same thing. Did you ever get this sorted ?
newfordy
1997 - 2003 F150
Nov 9, 2014 06:29 AM
drdave
Electrical Systems/Wiring
Jan 21, 2011 03:25 PM
JoSHN
Nov 8, 2008 07:56 PM
TallDaveWW
Aug 29, 2007 05:12 PM
rhoadc
Jul 24, 2006 11:17 PM
