Sport Trac Question
Old Feb 7, 2005 | 07:55 PM
CoachRice15's Avatar
CoachRice15
Sport Trac Question
I bought a 2003 Ford Sport Trac in Nov. of 2003. The wheel well on the right rear keeps getting really close to the tire. Close enough to rub where I can see the mark where it is rubbing, but it isn't bad enough where I can hear it. The dealership has already replaced this wheel well once. Any clues about what may be causing this? Thanks
Old Feb 8, 2005 | 07:04 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Feb 13, 2005 | 03:59 PM
highland boy's Avatar
highland boy
Right rear wheel well
That's interesting. I friend of mine noticed the same thing the other day. I have a 2002 Sport Trac 4x4 that I bought in Nov. 2004. I was thinking it was the studded winter tires I have on it, but that shouldn't be because they are the correct size. Maybe a design flaw? Does Ford have a replacement fix? I'm with you CoachRice15, does anyone know anything about this problem?
Old Feb 14, 2005 | 12:03 AM
XolieX's Avatar
XolieX
so with the sport tracs, are we finding problems with any kind of tires taller than stock.
i have the 235/70/16 tires, i now got 20 inch wheels with the same height tires, but these tires (255/45/20) are only made one company and expensive. and doesn't quite rub.
if i went with another size tire which is recommended from tire rack, would it rub? its .7 inches taller.
the recommended tire size from tirerach is a 275/45/20 which is .7 inches taller than stock. i am considering htese tires if i ever have to replace the tires. the 255/45/20 are the same exact size height as the stock tires, but only one company makes them are are 170 each tire.
