Power steering question
Old Feb 7, 2005 | 07:30 PM
nelee337's Avatar
nelee337
I just replaced the power steering gearbox on my 96 F150 xl. I had some bad leaks in my power steering gearbox, and I just got around to fixing it. The only problem is now it seems the engine is a little sluggish and it sometimes cuts off in the middle of driving. I was thinking the pump went bad because I drove it for some time with little or no power steering fluid. My question is, since the pump is connected directly to the engine could a bad pump have this effect?
Old Feb 7, 2005 | 07:50 PM
clipper1's Avatar
clipper1
The slugish part yes. But the cut of thing no. The belt will slip and squeal before it would kill the motor.
You should look to see if you maybe unhooked something when you were working on it.
