Duraspark II Ignition Module Failure?
Old Feb 7, 2005 | 02:05 PM
califasbob's Avatar
califasbob
Hello listers,
Yesterday I stepped on my '78 F-150 at a stoplight and after initially pushing me back in my seat, it sputtered. I started looking for somewhere to get it off the road, but it came back to life under 1500 RPM's. I got it to putter home, firing on all 8 cylinders provided that I kept the R's below 1500. It refired fine and idled very smoothly once home.
I happened to have an ignition module behind my seat as a spare, and I swapped it in. The truck runs great with the spare in place, so the problem is solved. I'm running a complete Duraspark II ignition from a 351M in the truck's 351C, which seems to work very well.
I'd always been under the impression that module failure=walking home. Is this something anyone on the list has ever experienced? I assume this is one of many ways these things can fail.
Just curious, thanks in advance, Bob
Old Feb 7, 2005 | 03:05 PM
F150daniel's Avatar
F150daniel
Usually they die for a second Radomly with the off time getting more often and longer up till it dies and never fires again.
those cheap parts store replacements last as long as motorcraft ones.
Old Feb 7, 2005 | 03:25 PM
califasbob's Avatar
califasbob
Thanks, Daniel. The one in there now is a Wells (Lord of Ignition Darkness from what I gather), so I'll pick one up on the way home and slip this one back behind the seat just in case. From what you say, it sounds like I was lucky to be near home!
Bob
Old Feb 7, 2005 | 03:26 PM
Mil1ion's Avatar
Mil1ion
Where did you get the 351C from ? Must have been swapped in ?
That's quite rare since they stopped making them in the early 70's
AFA the module is concerned make sure there is enough space behind it when it's mounted for air to cool it.
Old Feb 7, 2005 | 03:34 PM
califasbob's Avatar
califasbob
Mil1ion,
The C is just a block I scrounged up and built with flat tops and my re-conditioned 2V M-block heads. It's pretty mild with an RV cam, 600 CFM carb and Edelbrock Performer. I attached it to a rebuilt C-6 from an 80's E-150. I need to dig up the casting number on the block to see what year it is. But you're right, not the original motor.
Bob
abyars111
Feb 12, 2021 09:08 AM
reamer
Jul 9, 2017 12:08 PM
Uni Moe
20
Sep 17, 2016 11:30 AM
oneminizut
151
Aug 26, 2013 08:26 PM
rcook18
Nov 6, 2004 01:35 PM
