Can anyone here help me?!
Old Feb 7, 2005 | 12:02 PM
72Torino's Avatar
72Torino
Exclamation Can anyone here help me?!
I've been searching for forums high and low and cannot find an appropriate forum to post this in.
I know this is a Ford TRUCK enthusiast site, but I do have a Ford, but its not a truck.
I have a rare 1972 Gran Torino with original Ram Air with a factory high-compression 351 Cobra Jet 4V.
Anyway, don't ban me
Here's my question:
<!-- message --> In my 1972 Gran Torino, weird stuff has been happening. The past few years when I have my driving lights on, all of a sudden my dash lights would go out, as with the horn, tail lights, side marker lights and front parking lights.
The interior light would still work as with my headlights and brake lights. 30 seconds later the driving lights and dash lights would "click" back on. Then it would repeat every minute --- "clicking" off. Then back on... doesn't seem to ever end.
I thought it was my horn shorting out, and I took that apart. Wasn't that.
So what can it be ? It only does this when engine is warmed up or so it seems.
Remember this only affects the: dash lights, horn, & parking lights.
Thanks in Advance guys
Old Feb 7, 2005 | 12:57 PM
Dealford's Avatar
Dealford
Welcome to FTE !
There are lots of Fairlane, Torino sites out there. Try Torino GT on Google.
When you said you would have your driving lights on, did you mean regular headlights (full lighting system), or aftermarket lights? As far as I know, the thermal relay in Ford headlight switches only shuts off the headlights, not the park/dash lights.
The horn is included? Wierd! Try disconnecting one wire at a time from the horn relay to try to isolate the problem. I could only guess that 2 wires from these separate circuits have rubbed together somewhere. To further the guess, I'd look at the hot lead into the horn relay first &/or the hot lead into the park/dash lights.
Good luck finding the problem.
AL.
Old Feb 7, 2005 | 02:46 PM
72Torino's Avatar
72Torino
lol, I do, but its mostly for mustangs!
Normal lights (shuts off even if you just turn on the parking lights... dash & horn go off too)
Tell me about it, the times I need a horn, its shut off!
Thanks Al, you've been the most help out of all the forums I've been on !
Darryl
Old Feb 7, 2005 | 06:24 PM
Lee Lichterman's Avatar
Lee Lichterman
I would grab a Haynes if you don't have one already. There should be schematic wiring diagrams in the back. With it cycling on and off, I am betting you have a circuit breaker being overloaded and it is tripping off, then cooling down and coming back on until it overheats again and shuts down etc etc.
The wiring diagram should show if the horn shares the same power as the parking lights. If so, just troubleshoot that circuit and look for chaffing wires on metal somewhere, probably around a grommet, against a frame rail etc.
If they are on different circuits, then my bet is the lights have lost their ground and the circuit is using the horn as the ground or vice versa but lights are famous for breaking ground wires and backfeeding.
Good Luck,
Lee
Old Feb 7, 2005 | 06:55 PM
72Torino's Avatar
72Torino
Thanks a lot Lee.
Haynes, here I come (not the underwear)
Old Oct 7, 2005 | 09:56 AM
cpettymore7777's Avatar
cpettymore7777
the horn goes thru the light switch. i have the same problem with my 1980 f150. im going to replace the light switch to see if that works
Old Oct 7, 2005 | 01:48 PM
Franklin2's Avatar
Franklin2
I thought you guys had lost it when I read that, but I looked it up and you are right. I never noticed that before. The headlight switch in 1980 has two circuit breakers in it. One for the headlights, and one for the horn.
I learn something new everyday!
