Aerostar Ford Aerostar
Engine temp bewilderment
Old Feb 8, 2005 | 12:00 PM
eds94aero's Avatar
eds94aero
Bewildered
Originally Posted by eehoepp
My Aerostar had the same problem three years ago. It was the water pump.
I had tried everything else first (T-stat, rad cap, flushed the system, etc.) & the problem stayed. The pump was the last thing to change.
There were no blades left on the impeller. I am not sure how it still managed to pump ANY coolant (convection and good will?) at highway speeds, but it did.
After I changed the pump the temp always stayed rock steady.
A vice-grip chain wrench gets enough grip on the fan shaft to loosen it from the pump. And they are useful for other projects, too.
Cheers,
Eric
Thank you for the reply Eric!
I appreciate the help. I'm going to replace the NAPA stat' with a Motorcraft part and pull and check the water pump.
Thanks again!
Ed
Old Feb 8, 2005 | 12:09 PM
eds94aero's Avatar
eds94aero
Cheers,
Eric
Thanks for the reply. I have thought about the possibility of a bad pump but thought the actual possibility was extremly remote. Now I feel justified in pulling the pump. I'm also going to also replace the NAPA stat' with a Motorcraft part as long as I'm in there.
Thanks Again!
Ed
Old Feb 8, 2005 | 12:14 PM
eds94aero's Avatar
eds94aero
Bewildered
Originally Posted by krankshaft
Also as I recall there are special tools to remove the clutch you can rent they're not mandatory but they make the job easier also remember the clutch has a left hand thread you must turn clockwise to loosen it.
TYhanks for the suggestion. I am going to pull the pump and check it out and replace the NAPA stat' with a Motorcraft part while I have it apart i'll check out the clutch.
Thanks Again!
Ed
Old Feb 12, 2005 | 12:13 PM
bear2x2's Avatar
bear2x2
eds94areo what part of the country do you live in? If is a hot climate I recomend puting in a 2 row radiator from an explorer in it. I got a brand new one from Auto Zone for $180 bucks. Now in the Las Vegas summers I have a much staler temp control.
Hitagain
Mar 22, 2016 07:19 PM
GreenMachinee
Dec 3, 2014 04:57 PM
tjc transport
General Automotive Discussion
Nov 9, 2014 07:06 AM
DeadBody
16
Dec 30, 2012 09:32 PM
Lock
20
Jul 17, 2010 10:36 PM
