New Truck
Old Feb 7, 2005 | 05:50 AM
Soundsofascience's Avatar
Soundsofascience
New Truck
Hey guys, I'm new here, mostly because of my new truck. I just purchased a 1997 F-150 XLT with the 4.2 V6. At first i was sceptical, we've always had trucks in my family, Ford trucks at that, but never one with a V6. Given that all of you have a truck very much like the one I'm picking up on thursday, I was hoping you could share some wisdom. But my one big concern is simply "Will I enjoy it, even though its not a V8?"
Now, I dont plan on going 4x4'n in it (2wd is part of the reason, lack of a budget to replace something that might break is the other) but if I go skiing on a bad day or need to tow someone, is it going to cut it? Wll having another few ft-lbs with a 4.6 or 5.4 make much of a difference?
Thanks guys.
Ben
Old Feb 7, 2005 | 06:54 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Feb 7, 2005 | 07:11 AM
cantrma's Avatar
cantrma
For occasional use, the 4.2L will do just about anything. It may not tow a big load as fast, etc. but with patience it'll work. I always drive a 4x2. No 4x2 pickup has any traction in slippery (snow, ice, mud) conditions, or at least not enough to pull someone out of a ditch.
Old Feb 7, 2005 | 09:34 AM
true4.2's Avatar
true4.2
That's not true. I've pulled our minivan out of a ditch! Of course it wasn't dry at all and the ditch was only about 2 feet deep.
