how much torque with bullydog
Old Feb 5, 2005 | 10:38 PM
vancouverpower's Avatar
vancouverpower
I'm looking at buying a bully dog 6 postion chip. The max gain in hp, they claim, is 140. They don't mention anything about torque. Has anybody here ran one of these on the dyno? I was wondering how much the torque jumed up.
Also can the rig be ran down the road at the highest setting or is it worthless? I don't want it to heat up after a 1/4 mile . I have a choice of four settings to have it built with, don't want the 140 hp if it can't be used.
1999.5 f250 4x4 straight pipe, kwik filter, boost and pyro gauges
Old Feb 6, 2005 | 01:58 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Most of the big (100+ HP) chips I've seen dyno make low to mid 600's in torque....which represents about a 200 ft. lb. improvement over stock.
Old Feb 6, 2005 | 08:57 PM
vancouverpower
You must be talking about rear wheel numbers right? I thought the 99 psd made 500 torque, but that must be at the crank. So stock they must make 400 at the tire?
Old Feb 6, 2005 | 09:45 PM
444dieselrod's Avatar
444dieselrod
My dyno sheet says 468 F/LBS and that was at the rear wheels on an OBS, but I think the dyno operator was a lil screwy. I have never been on a dyno to get another. If that helps any.
Diesel Rod
Old Feb 7, 2005 | 07:38 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yep. Rear wheel numbers.
