t5 swap
Old Feb 5, 2005 | 09:14 PM
donsboy's Avatar
donsboy
t5 swap
hey guys whats new? Has anyone swapped a t5 into one of our trucks using the original clutch linkage? I'm looking at the california mustang kit to swap a t5 in place of a toploader. Pretty nice kit they have. I know the mounts wont work in the truck but the adapter plate looks good. anyone tried it or have any other suggestions. thanks Don
Old Feb 6, 2005 | 08:56 AM
truckfarmer's Avatar
truckfarmer
A friend of mine did the swap into a 61 F100 with a Y-block using the stock bellhousing and clutch linkage. Go to http://www.badgerlandf100s.com/ and look in the tech articles on how to do the swap. This is the second one they did. First was in a 56 with a 223 6 cylinder.
Old Feb 23, 2005 | 01:57 PM
65f100CoryE.'s Avatar
65f100CoryE.
I am really interested to know if anyone has seen this or done this same install on an FE..... would love to do it... just want the information up front.
Old Feb 23, 2005 | 05:39 PM
stevef100s's Avatar
stevef100s
I never did it with an FE, but I HAVE installed T-5's in 65 and 66 F100's with a small block. I bolted an aluminum Mustang aftermarket clutch quadrant to the factory slick 60's clutch rod lever. Then I used a hole saw, and bored a hole for the Mustang clutch cable to seat in. It's a little tough routing the cable though. Also, a T-5 doesn't hold up very well behind a 347 stroker in a pickup. It was a World Class T-5 out of a 94 Mustang Cobra, too Besides that, the shifter interferes with a bench seat, unless you fabricate an offset bracket to locate the shifter about 2 inches towards the front of the truck.
Old Feb 23, 2005 | 10:02 PM
65f100CoryE.
What would be the next best option to an np-435 i can not stand the gears......I would prefer to stay a standard though.
Old Feb 23, 2005 | 11:16 PM
TremecGT's Avatar
TremecGT
A tremec 3550 with the three mounting locations for the shifter would be a good soulution, Im ocnsidering it for my planned 351W swap, just dont know about the clutch linkage, maybe a hydrolic??
carrfamilynj
Mar 13, 2011 10:12 PM
neumannfamily
Apr 13, 2009 06:25 PM
jd_boggs
Apr 10, 2005 06:38 PM
60tokick
Engine Swaps
Jan 4, 2005 09:56 AM
