Sponsored by: Real Truck
Superduty's Have Shrunk!!
Old Feb 5, 2005 | 08:22 PM
marspec's Avatar
marspec
Did first oil change on my 05 today. Was suprised that I couldn't get under the truck when on my creeper. Needed another two inches or so. Was able to do it on 95. Went to the scales to make sure I hadn't gained that much weight!!!
Couldn't even get the gallon jug under the Fumoto after I installed it!! Guess I'm going to have to make some ramps for all four wheels to raise it a few inches so it sets level.
Old Feb 5, 2005 | 08:36 PM
Pittsburgh-05HD's Avatar
Pittsburgh-05HD
I think I could do jupping-jacks under mine...LOL What did the scale say? I am 6'6, 345# and no problems at all. Changed my oil today at 1500 Miles
Old Feb 5, 2005 | 08:39 PM
Bear Hunter's Avatar
Bear Hunter
mars...do you have a 2WD?
Old Feb 5, 2005 | 09:38 PM
marspec's Avatar
marspec
Yup - 2WD with 18" wheels. But then the 95 was also 2WD. This was my first go around under the truck - found the horizontal fuel module and tried to trace wiring to trailer lights so I could tap them and put a connector in the bed. Was suprized to find a steering stabilizer though.
Old Feb 6, 2005 | 06:04 AM
scraprat's Avatar
scraprat
Top Answer: 5
Yes...I was also surpised to see a steering stabilizer also.
Old Feb 6, 2005 | 08:08 AM
nisiar's Avatar
nisiar
marspec, Can you put a tape measure to that clearance? I've ordered a 2wd myself.
Old Feb 6, 2005 | 12:28 PM
marspec's Avatar
marspec
nisiar - most dimensions are in the 12-13 inch area.
Cab Steps - Factory 12-13
Trans support 12
Air Dam 10-11
Oil Pan is 12
Bracket holding front axles from going aft 12
My creeper ground clearance is 3
Pittsburgh - Scales read 201. I'm 6 ft even. I must admit even though I haven't gained any weight these past few years some of the weight is losing its battle with gravity.
glong15650
6.7L Power Stroke Diesel
66
Nov 3, 2014 01:41 PM
bryanlindborg600
Aug 6, 2009 04:15 PM
erikl85
Apr 27, 2003 12:10 AM
