Winter front for radiator?
Old Feb 5, 2005 | 07:09 PM
packrat56's Avatar
packrat56
So, I have a 56 with an old 302. The fan does not have a clutch, the shroud is open, I am having carb icing and very slow warm-ups. I drive it to work every day, and winters are damp and cold. Cardboard on the radiator helps a lot. Does anyone make a "winter front" for a old ford? Something like a big truck, something perhaps that goes right on the radiator under the hood, with flaps? I know I can make one, but anyone seen one for sale?
Ideas?
Old Feb 6, 2005 | 07:28 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Packrat,
At 80 degrees or 20 below zero, my '02 Wrangler's thermostat doesn't open until 4 miles from my house...almost like clockwork. Perhaps instead of trying to make the truck heat up faster you might invest in one of those electric heaters that plugs into the cigarette lighter. I know this won't help with carb icing but it should make your damp and cold ride more comfortable.
Vern
Old Feb 6, 2005 | 12:06 PM
packrat56's Avatar
packrat56
I can handle the cold mornings, but its the truck not running well that I am trying to correct. The heater idea is good, Ill think about that one..
Old Feb 6, 2005 | 02:30 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
Maybe a warmer thermostat you aren't running a 160° unit during the winter are you? If it is cool enough you could try to take the fan off and run the truck for a day or two and see if that helps. If it does I would try an electric setup with a thermostat controlled fan and a bypass switch just in case. You could also try a better thermostat. I put a cheap $5.00 one in originally in my 1995 Jeep Wrangler and it would run hot. I put one of the more expensive $13.00 thermostats and it made a world of difference same teperature. The thermostat regulates the temperature better. The cheap unit had a large swing in temperatures. That was almost 2 years ago.
Old Feb 6, 2005 | 02:32 PM
Madathlon's Avatar
Madathlon
depanding on the room U have between the Rad, and the grill.. U could adapt a bigrig louver set for ur truck.... And I get a block heater right off the bat to keep ur engine warm and that will help big time also...
Old Feb 6, 2005 | 06:53 PM
Randy Jack's Avatar
Randy Jack
Packrat56 -
My vote would be for a temperature-switched electric fan. Maybe a warmer thermostat too. I have that setup and really like it. warms up quick. runs nice no matter what the traffic or weather. Must be why so many newer cars come that way.
Old Feb 6, 2005 | 07:12 PM
packrat56's Avatar
packrat56
Indeed, that is the way I hope to go as well. At this point the money is just not there. (about $160-200 ??) I guess this is a temporary measure untill I can do the electric fan.
Is there a good quality, yet inexpensive way to do the electric fan?
Old Feb 6, 2005 | 07:21 PM
Christopher2
Veteran: Navy
I would go to a salvage yard and start looking at newer cars with electric fans. Anything with a transverse motor Ford Focus might be a candidate. I bet that is something you can get fairly cheap. Maybe from a rear ended car? Might be able to trace the wiring and see if it has a thermostatically controlled switch.
Old Feb 6, 2005 | 07:30 PM
Randy Jack's Avatar
Randy Jack
Packrat56 -
I am 2 iterations into the electric fan deal (long story). About $160 for the final setup. I bought the fan from Summit ($120) and the switch kit (Hayden #3652 - $40) from Pep Boys. I run my fan mounted on the back side of the radiator (puller) without a shroud. The switch kit uses a probe switch that inserts thru the radiator fins. The electrical hookup was no biggy. The whole install should take a day, including removing the old hardware.
You don't have to go overkill on the fan cfm. Mine is only 1600 cfm. I have had the setup for over a year now and have run in everything from 100+ degree stop and go traffic to 80 mph freeway. No problems. In fact, I need a hotter thermostat because it tends to run too cool.
You'll love it, when you do it.
little56ford
Jan 24, 2014 11:08 AM
RRranch
73
Jan 15, 2010 10:24 AM
46yblock
1947 and Older Ford Trucks
Jul 18, 2007 11:24 PM
1954F250
Sep 26, 2006 04:27 PM
jwtaylor
110
Sep 1, 2003 07:12 PM
