Vibration is gone
Old Feb 5, 2005 | 05:10 PM
edmundrsku's Avatar
edmundrsku
Vibration is gone
After 11 months and four trips to the shop, the vibration problem (40 - 60 mph only with foot on the accelerator) on my 2004 FX-4 SCAB has finally been fixed. Previous fixes that did NOT work were wheel force balancing, driveshaft change out, vibe damper, driveshaft angle shim (this helped somewhat) etc. This time they changed the entire rear axle assembly, FP Number V-953-R. The truck is smooth as silk under all conditions !!!
Old Feb 5, 2005 | 07:00 PM
truebluefx's Avatar
truebluefx
sounds like your truck spent alot of time in the shop.. but as long as they fixed the problem for free.. I always get a free rent-a-car to drive when mine goes in the shop anyways!
Old Feb 5, 2005 | 08:27 PM
WVF150's Avatar
WVF150
My Truck Goes In On Wedsday, For Drive Shaft Replacement Wish Me Luck !
Old Feb 6, 2005 | 09:34 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WVF150...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Feb 6, 2005 | 02:25 PM
texasmaker's Avatar
texasmaker
mine was fixed, broke, then fixed again
I went through the same thing. All the regular stuff then a new rear axle. It was OK for about 5k then started to vibrate again. I took it back and they rebuilt the front and rear differential this time. That was about 4k ago and so far so good.
Old Feb 8, 2005 | 09:04 PM
Kurious's Avatar
Kurious
edmundrsku, can you or anyone else tell me the difference between FP Number V-953-R and V-953-J? I noticed they replaced your rear axle assembly with V-953-R and you said you don't notice the vibe anymore. They replaced my rear assembly with V-953-J but I still feel the vibe. I'm wondering if your rear assembly is a new and improved one. Thanks!
tao
Offroad & 4x4
Apr 9, 2011 10:52 AM
messer0507
Nov 26, 2010 08:25 PM
brian Felts
Sep 28, 2010 05:07 PM
J Jones
2004 - 2008 F150
21
Mar 6, 2005 09:55 PM
leroys4wd
1997 - 2003 F150
26
Apr 10, 2004 12:08 AM
