Sponsored by: Auxito
engine problems
Old Feb 5, 2005 | 02:50 PM
Jack K's Avatar
Jack K
engine problems
Hi everyone ...new just today...have a F150, 4X4, Std trans '97, with a 4.2L engine and only 57K miles...6 months ago , due to leaking water [but never an overheat suituuation ] I had to have the timing case cover gasket replaced ...expensive.. and now a bad engine noise...strongly suspect a spun bearing, or bad wrist pin or piston skirt....the question is WHY...never dogged the engine or beat it up...hey I still am on the original brakes...Any engine or model recalls here? or any reasons why this happened? Suggestions?? i.e. can I reasonably expect to put only a crank kit in this or must I go for a rebuilt longblock [considering Jasper] any comments or suggestions would be appreciated..thanks, Jack
Old Feb 5, 2005 | 02:56 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Feb 5, 2005 | 03:03 PM
Jack K's Avatar
Jack K
Thanks Tim!
