Bronco II Ford Bronco II
4x4 low
Old Feb 5, 2005 | 12:43 PM
toby47421's Avatar
toby47421
4x4 low
I have an 88 bronco which is stuck in 4 low, i think the 4x4 motor is bad so i was wondering how to check it and what else could be wrong? any help is appreciated
Old Feb 5, 2005 | 02:53 PM
RomerB2's Avatar
RomerB2
Check the fuses in the fuse panel under the dash. I had this happen to me and I couldn't figure out what was going on, but it turned up to be just a 15 amp fuse down there. Hope this helps.
Old Feb 5, 2005 | 03:03 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
toby47421,
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE..
Check this out: https://www.ford-trucks.com/forums/s...d.php?t=300691
We are pleased you have chosen the best source for Fords!
Enjoy FTE ….
See you on the boards.
Old Feb 5, 2005 | 03:12 PM
RomerB2's Avatar
RomerB2
Oh yea, Welcome to FTE too! Haha I didn't even look at your posts. We'll look after you and your Bronco II.
